This configuration example assumes that VRs are already created and configured with regular VRRP parameters, but not yet enabled (enable vrrp {vlan [vlan_name | vlan_list] vrid [vridval | vrid_list} command is not yet executed). If VRs are already enabled, disable all the VRs (disable vrrp {vlan [vlan_name | vlan_list] vrid [vridval | vrid_list]}).create vrrp group “groupA”
configure vrrp group “groupA” add primary-vr vlan “vlan1” vrid 1
configure vrrp group “groupA” add secondary-vr vlan “vlan2” vrid 2 configure vrrp group “groupA” add secondary-vr vlan “vlan3” vrid 3 configure vrrp group “groupA” add secondary-vr vlan “vlan4” vrid 4 configure vrrp group “groupA” add secondary-vr vlan “vlan5” vrid 5
Or alternatively, VLAN tag range and VRID range can be specified. In this case, vlan1 has vlan-id 101, vlan2 has vlan-id 102, etc.:
configure vrrp group “groupA” add secondary-vr vlan 102-105 vrid 2-5
configure vrrp group "groupA" fabric-routing on
enable vrrp group groupA
enable vrrp
enable vrrp group groupA members
After configuring VRRP groups, the following appears for the below show commands:
# show vrrp group
Members
Group Name Priority State Count TP/TR/TV/P/T /FR
groupA(En) 100 MSTR 6 0 0 0 Y 1 Y
En-Enabled, Ds-Disabled, Pri-Priority, T-Advert Timer, P-Preempt
TP-Tracked Pings, TR-Tracked Routes, TV-Tracked VLANs, FR-Fabric Routing,
MX-Mixed values
# show vrrp vlan1
VLAN: vlan1 VRID: 1 VRRP: Enabled State: MASTER
Virtual Router: VR-Default
Priority: 100(backup) Advertisement Interval: 1 sec
Version: v3-v2 Preempt: Yes Preempt Delay: 0 sec
Virtual IP Addresses:
Accept mode: Off Group : groupA (Enabled)
Host-Mobility: Off
Host-Mobility Exclude-Ports:
Checksum: Include pseudo-header
Tracking mode: ALL
Tracked Pings: -
Tracked IP Routes: -
Tracked VLANs: -
Fabric Routing: On
* indicates a tracking condition has failed
